8 years agoArria 10 DDR4 EMIF Burst Length Expansion
I'm working on an Arria 10 design where I would like to be able to support bursts of up to 512 words on the Avalon-MM interface into the SDRAM DDR4 EMIF. This parameter is not configurable in the IP ...
8 years agoIsn't one of the purposes of the QSYS interconnect logic to generate fifos and adapter logic to manage the different widths and burst capabilities of interfaces?
From the quartus handbook (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts_qii5v1.pdf), p.8-16: using bridges to minimize adapter logic Qsys generates adapter logic for clock crossing, width adaptation, and burst support when there is a mismatch between the clock domains, widths, or bursting capabilities of the master and slave interface pairs. Qsys creates burst adapters when the maximum burst length of the master is greater than the master burst length of the slave. The adapter logic creates extra logic resources, which can be substantial when your system contains master interfaces connected to many components that do not share the same characteris‐ tics. By placing bridges in your design, you can reduce the amount of adapter logic that Qsys generates. This tells me that adding an Avalon-MM Pipeline Bridge with my desired max burst size will implicitly add all the required burst size adaptations. Should I be wary of this assumption? Thanks, Andrew
