Arria 10 - Avalon MM DMA for PCIe crashes the PC when re-initializing the descriptor controller
- 3 years ago
The pin_perst is the power on reset of the FPGA board, when you reboot the host, it will toggle the pin_perst. Where the npor is driven by soft reset (user application), but the soft reset will also bring down the link, once link being bring down, we need to rebooting the PC.
I have a discussion with another PCIe specialty, it seem like there is no other alternative to reset the DMA controller alone beside reboot the PC.
Hope this answered your question.
Wincent_Intel
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Is it the post mentioned in your second reply able to help you to solve your problem ?
Wei Chuan
- ThomasKindler3 years ago
Thanks for looking into it!
As said, the hot reset is only a workaround - it takes ~1s, and as I understand, may reset other devices connected to the same bridge.
So an official sequence to reprogram the descriptor controller's descriptor table registers would be preferred.
