AN829 simulation ran but failed
- 3 years ago
Hi David,
Please accept my apologies for late reply.
I was able to run a full compilation based on the .qar provided by you without any error in Quartus v21.3.
Could you please try to run again ? or maybe in another device/PC...
If the issue still happens, you may refer to Intel FTA PCIe document
https://community.intel.com/t5/FPGA-Wiki/FTA-PCI-express/ta-p/735993
It mentions steps to debug the LTSSM.
Hope this is helpful to you.
Wincent_Intel
Hi David,
Wincent_Intel
Hi Wchiah
An829 has a DDR interface, that is very attractive to serve as an example. for some reason it is not very straight forward to a newbie.
I use the platform designer to create a Pcie interface from scratch and generate simulation. seems this time the simulation can run through.
I put it in a new thread.
how to Integrate PCIe DMA to replace USB3 interface - Intel Communities
hope you will be assigned to this new thread and give me some suggestion.
Thank you very much,
David
