Amchardy
5 years agoAN690 PCIe Gen3 x8 MM DMA altera_dma driver issues
I'm having issues getting AN690 up and running on my A10 GX Dev Kit. I can successfully program the device and see the device listed when I run lspci -vv (as seen in the screenshot below)
Howe...
SengKok_L_Intel
5 years agoThis seems like there is OS dependency. After changed the $major value, did you see the driver listed in the /proc/devices?
Before running the driver, did you compile the driver and application by using the root account?
Regards -SK
Amchardy
5 years agoNo, unfortunately I do not see it listed in /proc/devices. I do see altera_dma listed when I run lsmod.
All steps were run as root.
