AN690 PCIe Gen3 x8 MM DMA altera_dma driver issues
Per AN690 section 1.6.1 Installing the Linux Software, you will expect to get an error message when you install the driver for the first time.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an690.pdf
This may not the same error as what you encounter, just to ensure after you have installed the driver again, you are failed to execute the ./run?
For the AN829, did you add the device family after the command? For example: "sudo ./install arra10"
Regards -SK
Hi, I get the "ERROR: Module altera_dma does not exist in /proc/modules." message every time I try to run install. It always fails on the altera_dma_load stage of the Makefile. If I manually edit altera_dma_load to assign a $major value that is not currently in use by any device listed in /proc/devices then the driver will load. However when I execute ./run I just get no response (i.e. I don't see a print out of the options). It just sits there doing nothing.
For AN829 I have been executing "sudo ./install arria10".
Any other suggestions or troubleshooting steps I can try?
