MHMT
3 years agoAn error was reported for the IOB setting
I want to input the odr, DCLK dout0, dout1, dout2, dout3 into IOB, HTML code is as follows, but in the end the compile time error.
AqidAyman_Altera
3 years agoHello,
Thank you for reaching out Intel FPGA Community.
Based on the snapshot you shared, it shows a syntax error which means the issue is in the line or statement in the code which does not conform with the Verilog syntax rules. I would recommend you check first on any possible syntax error in the code or upgrading the Verilog version to the latest one and see if the issue is resolved.
Aqid
