UMall1
5 years agoALTLVDS_RX
I am using an ALTLVS_RX module in a Cyclone III device. Intel in its datasheet advises against using this module an recommends using BUS LVDS IO standards and logic to implement the function.
Why ...
EngWei_O_Intel
5 years agoHi
There are benefits over multipoint application for using BLVDS:
I crossed check the "High-Speed Differential Interfaces" section in
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc3/cyc3_ciii51001.pdf
and Table 1–31 in
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyc3/cyc3_ciii52001.pdf
The max data rate shall be 740 Mbps with freq of 370MHz if you are using Cyclone III LS device C7, I7 grade depending on the mode.
