10 years agoALTLVDS IP: Can serdes channels be placed into different IO banks?
Hello! I'm using cycloneV and trying to place ALTLVDS IP channels into different banks. Both TX and RX IPs are used with external PLL and channels placed into a single bank works fine, but if i...
10 years agoso you see the problem.
There are no paths between clock and data pins which met the requirements you gave it with constraining the pin-locations. It's really hard to get your problem correct. If you would post some more detail about it (maybe a block-diagram or some code with PIN-Assignments)?!
