gcohe5
7 years agoaltera gmii to sgmii ip timing problem
hi, i’m trying to run the a10_soc_devkit_sgmii (arria 10) project (https://rocketboards.org/foswiki/Documentation/GSRD181ReleaseNotes#Release_Contents 1) with some modifications. I’m running into s...
KennyT_altera
6 years agoThanks, I manage to run the full compilation on your design.
Did you follow the constrain provided in cv_soc_rgmii_5csxfc6.qar files? As I compare the sdc that you have written, there are some missing clock like the create_generated clock which is use of the switch.
Can you review your sdc again and match with the example above?
