10 years agoALT PLL Megawizard aborts
in qsys ALTPLL component aborts at starting.the component flashes in to qsys and then disappears. I used it properly till yesterday.all of a sudden, ALT PLL is not opening in qsys. i tried re inst...
10 years agoThere may be a problem with your project. Try creating a new blank project and see if you can use the ALTPLL component. If you can, you might try re-creating your project. It might also be caused by files in one of the .quartus directories in your home folder. I'm not sure how to fix these.
