PAA
1 year agoAgilex5 mipi phy IP configuration issue
We are attempting to test CSI IP on Agilex5 on AXE5-Eagle Arrow Development board, and find that the byte Location assignments on the mipi phy seems to have bug, as it does not allow us to use odd by...
Wincent_Altera
1 year agoHi,
If we assign odd bytes and attempt to compile, it results into signal connection errors. No such error is seen for even byte assignment
>> if you refer to our user guide under 4.1. Identifying Pin Assignments Based on Byte Location
>> MIPI D-PHY design using 2 data lanes and 1 clock lane assigned to byte location 7
>> Hence, the scenario you seeing is expected.
>> you may need to assign the remaining unused pin to prevent the error
>> 4.4. Using the Remaining I/O Pin from Same Byte Location
Hope that clarified ,
Wincent_Intel
