Agilex5: How to use a GTS refclk to clock the FPGA fabric?
- 3 months ago
posted minimal design doesn't work because it doesn't connect system PLL output to anything, thus the PLL is discarded during synthesis.
Modified top.sv respectivelyassign {//pad_rled0, pad_gled0, pad_bled0, pad_rled1, pad_gled1, pad_bled1, pad_rled2, pad_gled2, pad_bled2, pad_rled3, pad_gled3, pad_bled3} = 11'o213; //12'o4213; assign pad_dbg_tx = pad_dbg_rx; assign pad_rled0 = clk101p768092; assign clk101p768092_ready = 1'b1;
Connecting the PLL reveals another error. The fact that you never got to this point suggests that the PLL wasn't implemented in your design, e.g. due to missing connectivity.Error(22849): Intel FPGA IP instantiated in the design requires the DEVICE_INITIALIZATION_CLOCK option to be set to either OSC_CLK_1_25MHZ, OSC_CLK_1_100MHZ, or OSC_CLK_1_125MHZ. This assignment is missing in the QSF file.
Added
set_global_assignment -name DEVICE_INITIALIZATION_CLOCK OSC_CLK_1_100MHZ
Get still complains about missing constraints, but design basically compiles now.
Frank
P.S.: Don't know, if DEVICE_INITIALIZATION_CLOCK is actually required to run system_pll. GTS PHY itself needs it according to device handbook.
I've attached a zip file for a minimal project. On Linux it can be extracted using:
mkdir /tmp/fpga-forum
cd /tmp/fpga-forum
unzip ~/Downloads/project.qar.zip
quartus_sh --restore project.qar
cd /tmp/fpga-forum/scratch/fpga/builds/tests/axe5-eagle/80902c4/quartus
quartus project.qpf &
- CheepinC_altera3 months ago
FvM Appreciate your help on this case. Your explanation and elaboration are very helpful.
zener Feel free to test out Frank's later recommendation which is compiling correctly and keep us posted if there is any inquiry. Thank you.
