Agilex5: How to use a GTS refclk to clock the FPGA fabric?
- 3 months ago
posted minimal design doesn't work because it doesn't connect system PLL output to anything, thus the PLL is discarded during synthesis.
Modified top.sv respectivelyassign {//pad_rled0, pad_gled0, pad_bled0, pad_rled1, pad_gled1, pad_bled1, pad_rled2, pad_gled2, pad_bled2, pad_rled3, pad_gled3, pad_bled3} = 11'o213; //12'o4213; assign pad_dbg_tx = pad_dbg_rx; assign pad_rled0 = clk101p768092; assign clk101p768092_ready = 1'b1;
Connecting the PLL reveals another error. The fact that you never got to this point suggests that the PLL wasn't implemented in your design, e.g. due to missing connectivity.Error(22849): Intel FPGA IP instantiated in the design requires the DEVICE_INITIALIZATION_CLOCK option to be set to either OSC_CLK_1_25MHZ, OSC_CLK_1_100MHZ, or OSC_CLK_1_125MHZ. This assignment is missing in the QSF file.
Added
set_global_assignment -name DEVICE_INITIALIZATION_CLOCK OSC_CLK_1_100MHZ
Get still complains about missing constraints, but design basically compiles now.
Frank
P.S.: Don't know, if DEVICE_INITIALIZATION_CLOCK is actually required to run system_pll. GTS PHY itself needs it according to device handbook.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Pasting the above into 'cat | base64 -d | xz -dc > gts_system_pll.ip' should result gts_system_pll. ip with an md5sum of e0eeb0ab0cd45da5eb19b385cef0ca56.
