Agilex5 GTS Reset Sequence
- 1 year ago
Referring back to your initial observation that suggests a possible FPGA configuration failure, I believe it’s important to isolate this issue first.
Would you be able to try programming the device directly via JTAG to confirm whether the FPGA can be successfully configured? From my understanding, the XCVR reset typically does not impact FPGA configuration, as the transceiver logic only starts operating after a successful configuration.
Unless the message “FPGA reconfiguration failed” is referring to something else (e.g., a soft reconfiguration or user logic indication), it may not be a true configuration failure.
Please let me know if you have any concerns or need further assistance. Thank you!
Chee Pin
Thank you for filing this case and sharing the details. As I understand it, you have some inquiries related to the GTS XCVR reset sequence. Please allow me some time to review the information, and I’ll get back to you as soon as possible.
