SamJak
2 years agoAgilex Triple Speed Ethernet tcl script error
Hi, I'm using AGFB014R24B2I3V device in my custom project. Generated hardware design by following TSE Onboard PHY chip reference design. To test SGMII interface for PHY 88E1512 using TSE IP, tcl scr...
ZiYing_Intel
2 years agoHi,
According to the issue that you are facing, there are a lot of situations that might cause it happen such as maybe you are using multiple cable, multiple JTAG, multiple CPU, multiple host and got error in the tcl. I would suggest you to connect with single cable and single host if you are using multiple cable and host. Besides that, you also need to check back your tcl whether got any error in the tcl file since the error was occur after the "Starting TSE MAC Configuration System Console".
zying
SamJak
2 years agoHi,
I'm using single cable, single JTAG, single CPU, single host. Now it is getting stopped at a line as attached image.
