SamJakNew Contributor2 years agoAgilex Triple Speed Ethernet tcl script error Hi, I'm using AGFB014R24B2I3V device in my custom project. Generated hardware design by following TSE Onboard PHY chip reference design. To test SGMII interface for PHY 88E1512 using TSE IP, tcl scr...Show MoreTSE_error.png43 KB
ZiYing_IntelFrequent Contributor2 years agoHi,May I know you are using which quartus version? Best regards,zying
Recent DiscussionsStratix 10 fPLL is cascade source mode doesn't lockPCIe bringup in Agilex 5GTS JESD204C IP Evaluation Mode not workingR_Tile PCIEArria 10 DDR4 IP - Using Hyperlynx DDRx Batch Wizard With Failed Simulation Results
