brian1211
3 years agoAgilex EMIF error 14566?
I get a similar error on the same data pin on a 2nd EMIF instance. It appears the pinout follows all the requirements but still getting the errors below:
Error(14566): The Fitter cannot place 2 p...
brian1211
3 years agoDQS numbering helped one of the 2 banks. 2nd one still failed with the same error. So I just mirrored the one passing ones pinout to get the 2nd emif to get past it and that worked.
No accepted solution on this as they never could tell me what the problem was. Just giving a working pinout doesn't help, showing what is wrong is helpful because then others can avoid it.
