brian1211
3 years agoAgilex EMIF error 14566?
I get a similar error on the same data pin on a 2nd EMIF instance. It appears the pinout follows all the requirements but still getting the errors below:
Error(14566): The Fitter cannot place 2 p...
AdzimZM_Altera
3 years agoHi Brian,
That is accurate. What I mean is the connection between the IO Bank 2C and IO Bank 2D is not bonded.
I will attach the example design in .qar file.
brian1211
3 years agoAdzim,
I see the updated qsf from your *.qar file, but I don't understand what is wrong with the pinout we used. The banks and IO lanes used are the same just different DQ/DQS groups are in different locations. What rule is being violated?
