brian1211
3 years agoAgilex EMIF error 14566?
I get a similar error on the same data pin on a 2nd EMIF instance. It appears the pinout follows all the requirements but still getting the errors below:
Error(14566): The Fitter cannot place 2 p...
AdzimZM_Altera
3 years agoHi Brian,
I have checked the design at my side and I can see that the data pins placement are placed in IO Bank 2D while the Address and Command pins are placed in IO Bank 2C.
For your information, the IO Bank 2C and IO Bank 2D are not bonded in Agilex AGI027 devices.
That is why the pin placement cannot be made in those IO Bank.
You can use IO Bank 2F for the data pins and IO Bank 2C for Address and Command pins.
Adzim
