Agilex 7 slew rate reconfiguration
- 6 months ago
For configuring TX Equalization on the Agilex™ 7 FGT PMA, you can use register 0x47830, which controls the TX EQ parameters. You may also refer to the proc set_txeq_settings procedure in the file ttk_helper_ftile_9_25.tcl, as it provides an example of how these settings are applied.
Feel free to let me know if you have any further questions. Thank you.
I meant namely the slew rate. But we will need to change also some other of the PMA settings (like pre-emphasis, yes). Can you please provide a list of the registers where these parameters can be reconfigured?
- dncmrc16 months ago
Any hints about where file ttk_helper_ftile_9_25.tcl can be found?
- CheepinC_altera6 months ago
Sorry for the delay. Regarding the ttk_helper_ftile_9_25.tcl, you can download it from https://cdrdv2.intel.com/v1/dl/getContent/850450 . You may refer to F-Tile Architecture and PMA and FEC Direct PHY IP User Guide -> "A.5. Transceiver Toolkit Helper Script" for further details.
Thank you.
