Agilex 7 slew rate reconfiguration
- 6 months ago
For configuring TX Equalization on the Agilex™ 7 FGT PMA, you can use register 0x47830, which controls the TX EQ parameters. You may also refer to the proc set_txeq_settings procedure in the file ttk_helper_ftile_9_25.tcl, as it provides an example of how these settings are applied.
Feel free to let me know if you have any further questions. Thank you.
From your inquiry, I understand that you are looking into reconfiguring the TX slew rate for the Agilex 7 XCVR. Please correct me if my assumption is incorrect, but I am presuming you are referring to the F‑tile transceiver.
For your information, after reviewing the F‑Tile Architecture and PMA and FEC Direct PHY IP User Guide, I was not able to locate any specific info or configurable parameters related to TX slew‑rate control. Could you confirm whether you are instead referring to other PMA analog settings, such as TX pre‑emphasis?
Please let me know if you have any concerns or if you can share more context about your requirement. Thank you.
- CheepinC_altera6 months ago
Thanks for your clarification that you are referring to F-tile. As per my previous note, there is no configurable parameters related to TX slew‑rate control. Could you confirm whether you are instead referring to other PMA analog settings, such as TX pre‑emphasis? Thank you.
- dncmrc16 months ago
I meant namely the slew rate. But we will need to change also some other of the PMA settings (like pre-emphasis, yes). Can you please provide a list of the registers where these parameters can be reconfigured?
