agilex 7 Platform Designer PIO addr width
After you expand the BAR0 size, you'll need to expand some related modules inside PCIe PIO as well if you really need 2M size. if you'd like to check, a performance design like DMA doesn't always require a large BAR0. The way to use on-chip ram is important.
Since the PIO module does the AVST to AVMM transformation, here are some places I think you can try. Below filenames could be different from yours.
After the completion of Synthesis, you can find below module in ip/pcie_ed/pcie_ed_pio0/synth/pcie_ed_pio.v.
You may increase the PIPELINE_EN to a larger number.
This file ip/pcie_ed/intel_pcie_pio_g4_2431/synth/intel_pcie_bam_sch_intf_pipeline.sv does HIP to AVMM conversion.
Right there, you can find a 16KB FIFO here. I think you need to expand both read and write FIFOs for a larger amount of data.
Rong
