xiaohao's avatar
xiaohao
7 months ago
agilex 7 Platform Designer PIO 2x8
I used the Platform Designer PIO 2x8 example to build my own setup, but when I run lspci on the computer, I can only see one device pcie1, and cannot see pcie0. My hardware connections should be fine...
  • VenT_Altera's avatar
    VenT_Altera
    7 months ago
    Hi xiaohao
    Thank you for your updates.
    Please generate the PIO Gen4 x8x8 design example directly from the P-Tile AVST IP Parameter in Quartus. These configurations are supported for your use case:
    • Gen4 x8x8 512-bit (250 MHz or below) Endpoint
    • Gen4 x8x8 256-bit Endpoint
    This design example only supports the default settings in the Parameter Editor of the P-tile Avalon Streaming IP for PCI Express. Therefore, leave all parameters at their defaults and modify only:
    • Hard IP Mode
    • PLD Clock Frequency
    After that, click “Generate Example Design.”
    Refer to P-Tile AVST Design Example User Guide: https://docs.altera.com/r/docs/683038/24.1/p-tile-avalon-streaming-ip-for-pci-express-design-example-userguide/directory-structure
    Please let me know if you have any concerns.
    Ven
