agilex 7 Platform Designer PIO 2x8
- 7 months ago
Hi xiaohao
Thank you for your updates.
Please generate the PIO Gen4 x8x8 design example directly from the P-Tile AVST IP Parameter in Quartus. These configurations are supported for your use case:- Gen4 x8x8 512-bit (250 MHz or below) Endpoint
- Gen4 x8x8 256-bit Endpoint
This design example only supports the default settings in the Parameter Editor of the P-tile Avalon Streaming IP for PCI Express. Therefore, leave all parameters at their defaults and modify only:
- Hard IP Mode
- PLD Clock Frequency
After that, click “Generate Example Design.”
Refer to P-Tile AVST Design Example User Guide: https://docs.altera.com/r/docs/683038/24.1/p-tile-avalon-streaming-ip-for-pci-express-design-example-userguide/directory-structure
Please let me know if you have any concerns.
Ven
When changing from PCIe x16 to a dual x8 configuration, do I need to reassign the FPGA pins?
