Agilex 7 M EMIF User-Controlled Refresh
The Agilex 7 M EMIF user guide (UG 772538, version 2025.03.31) lists user-controlled refresh timing as a feature, but does not describe how to use that feature. I need to use this feature for my application, is it possible for documentation to be provided for this feature?
This is from table 18 which describes the controller's features:
"User-controlled refresh timing—optionally, you can control when refreshes occur and this allows you to prevent important read or write operations from clashing with the refresh lock-out time."
I assume this would be controlled using the mailbox interface from section 12, but there are no commands listed for controlling refresh timing.
- AdzimZM_Altera
Hi
Currently no option available to enable the User-Controlled Refresh feature in the EMIF IP.
I still waiting for confirmation if there is any mailbox command that can be used for this feature.
I will let you know once I get the details.
Adzim
- WillfulGoose
Hi Adzim, thank you for looking into it.
If it turns out this feature is planned but not yet released, please let me know if there is a way to get early access to documentation so that I can prepare my design ahead of time.
- AdzimZM_Altera
Hi
I have confirmed with engineering that this feature is not supported in Agilex 7 M-series device.
The UG will be updated with the correct information in future.
Sorry for any inconvenience cause.
Adzim
