Mikhail_a
9 months agoAgilex-7 AXI MCDMA for PCIe hang
Hi! I'm working with AGIB023R18A1E1VC device and having issues with AXI Multichanned DMA IP for PCIe. Since I require a PCIe bridge, I configured the IP in MCDMA+BAS+BAM mode (PCIe Gen 4, 512-bit)...
Mikhail_a
1 month agoHi!
Are there any updates about that issue?
I've tried to run example project on Quartus 26.1 and I still observe the issue. Now I can provide signaltap capture for any signals you may want. So I would ask for your help to solve this issue.
- VenT_Altera1 month ago
Hi Mikhail_a,
Could you please confirm the Design Example variant, user mode, application test, and the exact steps/commands you used to reproduce the error? This will help me to set up the same environment and replicate the error. It would also be helpful if you could provide the log that captures all the commands and their outputs.
Ven
