Mikhail_a
9 months agoAgilex-7 AXI MCDMA for PCIe hang
Hi! I'm working with AGIB023R18A1E1VC device and having issues with AXI Multichanned DMA IP for PCIe. Since I require a PCIe bridge, I configured the IP in MCDMA+BAS+BAM mode (PCIe Gen 4, 512-bit)...
VenT_Altera
8 months agoHi Mikhail_a
Thanks for reaching out.
May I ask the following to help us understand the issue:
- Could you attach the AXI MCDMA .ip file so we can review the parameter settings?
- Which design example variant and which driver did you use?
- Is the issue first observed in Q25.1, then in Q25.3.1? Did it work correctly prior to Q25.1?
- Are you using an Altera Dev Kit or a custom board?
- Could you share the STP when the issue occurs?
- Could you provide the exact steps to reproduce the issue?
Ven
