MamaSaru
1 year agoAgilex 5 with DDR4 DIMM fitter crashes
Hi, I have instantiated one EMIF for DDR4 DIMM. I cant' get successfull compile because the fitter crashes. Do you have any idea? I have attached the problem report and also the small project to ...
- 1 year ago
Hi Masaru,
I'm not sure right now why the Quartus got an error when using the Virtual pins for AXI4 signals in EMIF IP interface.
I will investigate further in future.
For the best option, you can start with the EMIF example design and modify with your own logic.
Such as replace the traffic generator with your own logic.
Adzim
MamaSaru
1 year agoI got successfull fit.
Thank you very much.
But in my original design, I put virtual pin assignment to all axi4 and axi4lite pins, and it doesn't consume any pins.
Is it illegal?
