Agilex 5 with DDR4 DIMM fitter crashes
- 1 year ago
Hi Masaru,
I'm not sure right now why the Quartus got an error when using the Virtual pins for AXI4 signals in EMIF IP interface.
I will investigate further in future.
For the best option, you can start with the EMIF example design and modify with your own logic.
Such as replace the traffic generator with your own logic.
Adzim
Hi Masaru,
I think this error occurred because the axi4 and axi4lite ports are export to top level file.
You can try to remove these ports from export to top level file and compile the design again.
I recommend generating an example design and start modifying the example design with your own logic.
Here is what I mean to not export the axi4 and axi4lite ports.
agilex 5 test
module Agilex5Test (
/*output logic s0_axi4_clock_out, // output, width = 1, s0_axi4_clock_out.clk
output logic s0_axi4_reset_n, // output, width = 1, s0_axi4_ctrl_ready.reset_n
input logic [34:0] s0_axi4_awaddr, // input, width = 35, s0_axi4.awaddr
input logic [1:0] s0_axi4_awburst, // input, width = 2, .awburst
input logic [6:0] s0_axi4_awid, // input, width = 7, .awid
input logic [7:0] s0_axi4_awlen, // input, width = 8, .awlen
input logic s0_axi4_awlock, // input, width = 1, .awlock
input logic [3:0] s0_axi4_awqos, // input, width = 4, .awqos
input logic [2:0] s0_axi4_awsize, // input, width = 3, .awsize
input logic s0_axi4_awvalid, // input, width = 1, .awvalid
input logic [13:0] s0_axi4_awuser, // input, width = 14, .awuser
input logic [2:0] s0_axi4_awprot, // input, width = 3, .awprot
output logic s0_axi4_awready, // output, width = 1, .awready
input logic [34:0] s0_axi4_araddr, // input, width = 35, .araddr
input logic [1:0] s0_axi4_arburst, // input, width = 2, .arburst
input logic [6:0] s0_axi4_arid, // input, width = 7, .arid
input logic [7:0] s0_axi4_arlen, // input, width = 8, .arlen
input logic s0_axi4_arlock, // input, width = 1, .arlock
input logic [3:0] s0_axi4_arqos, // input, width = 4, .arqos
input logic [2:0] s0_axi4_arsize, // input, width = 3, .arsize
input logic s0_axi4_arvalid, // input, width = 1, .arvalid
input logic [13:0] s0_axi4_aruser, // input, width = 14, .aruser
input logic [2:0] s0_axi4_arprot, // input, width = 3, .arprot
output logic s0_axi4_arready, // output, width = 1, .arready
input logic [511:0] s0_axi4_wdata, // input, width = 512, .wdata
input logic [63:0] s0_axi4_wstrb, // input, width = 64, .wstrb
input logic s0_axi4_wlast, // input, width = 1, .wlast
input logic s0_axi4_wvalid, // input, width = 1, .wvalid
input logic [63:0] s0_axi4_wuser, // input, width = 64, .wuser
output logic s0_axi4_wready, // output, width = 1, .wready
input logic s0_axi4_bready, // input, width = 1, .bready
output logic [6:0] s0_axi4_bid, // output, width = 7, .bid
output logic [1:0] s0_axi4_bresp, // output, width = 2, .bresp
output logic s0_axi4_bvalid, // output, width = 1, .bvalid
input logic s0_axi4_rready, // input, width = 1, .rready
output logic [63:0] s0_axi4_ruser, // output, width = 64, .ruser
output logic [511:0] s0_axi4_rdata, // output, width = 512, .rdata
output logic [6:0] s0_axi4_rid, // output, width = 7, .rid
output logic s0_axi4_rlast, // output, width = 1, .rlast
output logic [1:0] s0_axi4_rresp, // output, width = 2, .rresp
output logic s0_axi4_rvalid, // output, width = 1, .rvalid
input logic s0_axi4lite_clock, // input, width = 1, s0_axi4lite_clock.clk
input logic s0_axi4lite_reset_n, // input, width = 1, s0_axi4lite_reset_n.reset_n
input logic [26:0] s0_axi4lite_awaddr, // input, width = 27, s0_axi4lite.awaddr
input logic [2:0] s0_axi4lite_awprot, // input, width = 3, .awprot
input logic s0_axi4lite_awvalid, // input, width = 1, .awvalid
output logic s0_axi4lite_awready, // output, width = 1, .awready
input logic [26:0] s0_axi4lite_araddr, // input, width = 27, .araddr
input logic [2:0] s0_axi4lite_arprot, // input, width = 3, .arprot
input logic s0_axi4lite_arvalid, // input, width = 1, .arvalid
output logic s0_axi4lite_arready, // output, width = 1, .arready
input logic [31:0] s0_axi4lite_wdata, // input, width = 32, .wdata
input logic [3:0] s0_axi4lite_wstrb, // input, width = 4, .wstrb
input logic s0_axi4lite_wvalid, // input, width = 1, .wvalid
output logic s0_axi4lite_wready, // output, width = 1, .wready
input logic s0_axi4lite_bready, // input, width = 1, .bready
output logic [1:0] s0_axi4lite_bresp, // output, width = 2, .bresp
output logic s0_axi4lite_bvalid, // output, width = 1, .bvalid
input logic s0_axi4lite_rready, // input, width = 1, .rready
output logic [31:0] s0_axi4lite_rdata, // output, width = 32, .rdata
output logic [1:0] s0_axi4lite_rresp, // output, width = 2, .rresp
output logic s0_axi4lite_rvalid, // output, width = 1, .rvalid
*/output logic [1:0] mem_0_cke, // output, width = 2, mem_0.mem_cke
output logic [1:0] mem_0_odt, // output, width = 2, .mem_odt
output logic [1:0] mem_0_cs_n, // output, width = 2, .mem_cs_n
output logic [16:0] mem_0_a, // output, width = 17, .mem_a
output logic [1:0] mem_0_ba, // output, width = 2, .mem_ba
output logic [1:0] mem_0_bg, // output, width = 2, .mem_bg
output logic mem_0_act_n, // output, width = 1, .mem_act_n
output logic mem_0_par, // output, width = 1, .mem_par
inout logic [63:0] mem_0_dq, // inout, width = 64, .mem_dq
inout logic [7:0] mem_0_dqs_t, // inout, width = 8, .mem_dqs_t
inout logic [7:0] mem_0_dqs_c, // inout, width = 8, .mem_dqs_c
input logic mem_0_alert_n, // input, width = 1, .mem_alert_n
output logic [1:0] mem_0_ck_t, // output, width = 2, mem_ck_0.mem_ck_t
output logic [1:0] mem_0_ck_c, // output, width = 2, .mem_ck_c
output logic mem_0_reset_n, // output, width = 1, mem_reset_n.mem_reset_n
input logic oct_rzqin_0, // input, width = 1, oct_0.oct_rzqin
input logic ref_clk // input, width = 1, ref_clk.clk
