Agilex 5 EMIF-LPDDR4, AXI4 Read-Write Starvation Issue
Agilex5 EMIF IP controller tries to maximize the efficiency based on coming traffic data pattern and user can not control starvation and reordering option. Thus in that your case completing the sequential write command then read command is processed. You may want to order write and read command separately at AXi bus interface ie issue read command after write command .
- Phix338 months ago
Thank you yoichiK for your prompt reply,
So you confirm that Reordering and Starvation cannot be controlled !!!
For me it is a big problem because the host driving the AXI Write channel (the Writer) is fully independent from the host driving the AXI Read channel (the Reader). Moreover, the Reader cannot accept starvation because it drives a video sub-system with determinism and low-latency requirement.
By the way, it is not consistent/rational to handle reordering at EMIF side for effficiency reason and to ask my Reader to wait until the end of the Writer sequence.
Please, find below the Signal-Tap of the EMIF AXI4 R/W interface. On the below pattern, the Writer fully monopolizes the DDR during hundreds of commands (AWVALID/AWREADY). The Reader issue a few commands (ARVALID/ARREADY) then it waits for the data (RVALID) during around 2000 cycles (after the Writer stops), which is not acceptable.
In this use case, the only solution would be to stop the Writer each time the Reader issue a command, which leads to kill the overall efficiency...
If there is no workaround to control priority/reordering/starvation, I would be forced to conclude the Agilex 5 EMIF is not compatible with my need.
Thank you in advance if you have any suggestion...
- yoichiK_altera8 months ago
Contributor
I tried to replicate the issue at my side with Agilex5E devkit. and did similar data traffic on hardware.
I use async mode at AXI interface and burst length is 2 with consecutive write access. During consecutive write access one read access is issued and I see rvalid is returned before completion of consecutive write access.
