Agilex 5 dual simplex fitting
- 4 months ago
Hi Aleh_TS ,
I just sent you the passing design , please check your inbox.
I am using v25.1.1 previously.
Wincent
Hi AlehTS ,
Is weird, because I can get it pass 100 %
I am using "QUARTUS_VERSION "25.1.0 SP0.36 Pro Edition"
Wincent
Hi Aleh_TS ,
I guess, I sent you a wrong file, let me check back if I still got the file or not, else I will generate a brand new and sent to you again.
At the meantime, an you please try to remove the top file then replace with the one I share you earlier and try to recompile again ?
Wincent
- Aleh_TS4 months ago
I've used your modified file. Without it the Analysis failed.
Also I've sent you my pass\fail projects.
Thank you.
- Wincent_Altera4 months ago
Hi Aleh_TS ,
Means now with my top file, the analysis pass BUT the fitter is fail right ?
Give me sometime, let me dig back my previous project. Hope I can find back somewhere.
Wincent- Aleh_TS4 months ago
Actually I had to modify your file a little, to make it compilable.
So it is better to have your working version, so I can try it without modifications.
