Agilex 5 dual simplex fitting
- 4 months ago
Hi Aleh_TS ,
I just sent you the passing design , please check your inbox.
I am using v25.1.1 previously.
Wincent
Thank you, WIncent.
Unfortunately, your project has the same problem. Fitter-Plan is not able to find a legal placement.
I use q25.1.0 build 129, patch 0.36
Which one did you use?
BR
Aleh
- Wincent_Altera4 months ago
Hi AlehTS ,
Is weird, because I can get it pass 100 %
I am using "QUARTUS_VERSION "25.1.0 SP0.36 Pro Edition"
Wincent- Wincent_Altera4 months ago
Hi Aleh_TS ,
I guess, I sent you a wrong file, let me check back if I still got the file or not, else I will generate a brand new and sent to you again.
At the meantime, an you please try to remove the top file then replace with the one I share you earlier and try to recompile again ?
Wincent- Aleh_TS4 months ago
I've used your modified file. Without it the Analysis failed.
Also I've sent you my pass\fail projects.
Thank you.
