Aleh_TS
4 months agoAgilex 5 dual simplex fitting
Hello all. In my project I have to implement HDMI input and HDMI output. As a starting point I took an example design, which is generated from HDMI IP core. This example uses the dual simplex to p...
- 4 months ago
Hi Aleh_TS ,
I just sent you the passing design , please check your inbox.
I am using v25.1.1 previously.
Wincent
Aleh_TS
4 months agoHi Wincent.
My .v code is correct. Analysis and Synthesis pass well. The problem is in fitter.
Anyway, can you send me the whole your project (.qar), please.
Thank you.
Wincent_Altera
4 months agoHi Aleh_TS ,
I will sent the attachment via your registered email under *****@gxxxx.com
Please check your inbox.
Wincent
