Aleh_TS
4 months agoAgilex 5 dual simplex fitting
Hello all. In my project I have to implement HDMI input and HDMI output. As a starting point I took an example design, which is generated from HDMI IP core. This example uses the dual simplex to p...
- 4 months ago
Hi Aleh_TS ,
I just sent you the passing design , please check your inbox.
I am using v25.1.1 previously.
Wincent
Wincent_Altera
4 months agoHi Aleh_TS
I have attached the updated top.v file.
1) sda and scl signal is not connected at top.v
2) syspll_clk is mistakenly connected to syspll_lock signal.
Please try to adding the sda and scl signal in top.v and removing the connection between syspll_clk and syspll_lock
With the update i able to get the compilation passing. Can you please try it out ?
Else I would suggest you to continue with v24.2 which is working well - it save your effort.
Wincent_Altera
