pku_cfp
2 years agoafter THe .sof file is downloaded,the DDR4 IP works,why?
After powering on the circuit board with DDR4 and FPGA, it appears the DDR4 IP does not finish calibratin stage. The three signals of the local_reset_done, local_cal_success,local_cal_fail are all lo...
sstrell
2 years agoAre you saying that your board (custom board?) is supposed to be programming the FPGA automatically on power-up?
If not, then yes, you have to program the device manually before the EMIF will work.
