14 years agoaddressing on-chip memory(cyclone IV) from PC via PCIe
Hi freinds, I want to address a on-chip memory in the Cyclone IV FPGA via the HIP PCIe from my computer, so booth the HIP and the Memory are interconnected by the Avalon-MM interface. my ques...
14 years agoHi Ron,
--- Quote Start --- I guess I'll have to implement a DMA solution. --- Quote End --- Don't worry, you're not alone. I'm in the process of evaluating each of the PCIe cores. The Qsys PCIe core is not particularly useful. The PCIe-to-Avalon-MM bridge should really have inbound translation window remapping, and should have a built in DMA controller. It also has some timing issues: http://www.alteraforum.com/forum/showthread.php?t=35678 Next I'll be looking at the MegaWizard design flow. matthias, do you know of an existing DMA controller that supports scatter-gather lists on either the Avalon-MM side or PCIe side, with scatter-gather entries described by 64-bit PCIe addresses, Avalon-MM addresses, etc? If I can't find what I want, I'll just write one (a statement that is much easier said than done). Cheers, Dave
