10 years agoAccumulator in IP and RTL timing errors
Hello, I've implemented accumulator that computes the sum of 19-bit incoming data samples magnitudes for particular period of time to 33-bit bus. I use RTL: always @ (posedge clk) if (frame)...
10 years ago --- Quote Start --- I've tried it. It still give me the same -14 ns error at the accumulator output. --- Quote End --- That can't be right. You have either applied multicycle to another path or your constraint is ignored.
