about xcvr_vccr_vcct_voltage set
- 5 years ago
Welcome.
So, if your on board power supply typical value is 1.03V and may fluctuate till max 1.06V/1.07v then maybe still fine but if your typical value is already 1.06v/1.07v then it's a bit high and out of recommended operation condition from Arria 10 datasheet.
HI Lambert,
FPGA TYPE : arria 10, 10ax115n2f45e1sg
Quartus setting of 0.9V, 1.0V and 1.1V basically correspond to on board supply of 0.95V, 1.03V and 1.12V.
- 1.1V/1.12V setting is only applicable to GT channel only while I presume you are using GX channel
For GX channel, Transceiver speedgrade of 2, data rate = 12G,
- You should be using 1.03V as per A10 datasheet table 20 Transmitter and Receiver Data Rate Performance (page 25)
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_datasheet.pdf
- May I know why are you using 1.07V ?
In general, you can always refer to A10 datasheet doc for the guidance of correct transceiver power supply to be used.
dlim
Hi dlim,
Thanks for your help, just because I provide one very close value to 1.06v(maximum, 1.07v just because of the power accuracy adjustment). And from your information, I got the indication of 0_9v, 1_0v, 1_1v, thanks.
Brs,
Lambert
