16 years agoabout the signal of "ff_rx_dsav"
when I simulated the Triple speed ethernet MAC,I added a data interface contro module to the mac,I found the signal ff_rx_data[7:0] have data stream out,but there are serval "00" bytes in the stream and the signal ff_rx_dsav was deasserted and rx_err[5:0]=6'b000110,how does that happen? I set the mac interface register as following: register offsetregister namevalue0x08command_config0x0080_00330x04scratch0xAAAAAAAA0x0Cmac_00x17231C00 0x10mac_10x0000CB4A 0x14 frame_length 0x5ee 0x18 pause_quant 0x0f 0x1C RX_section_empty 0x10 0x20 RX_section_full 0x10 0x24 TX_section_empty 0x100x28 TX_section_full 0x10 0x2C RX_almost_empty 0x08 0x30 RX_almost_full 0x08 0x34 TX_almost_empty 0x08 0x38 TX_almost_full 0x0A ox3c 0x00 0x5c 0x0c 0xe8 0x00 0xec 0x003 Replies
What are you sending on the MII side? The error word that you get seems to indicate "CRC error" and "Invalid frame length"
Thank you for your reply! Firstly,I added data stream to "ff_tx_data",then the gm_tx_d[7:0] have data out. secondly,I copy the out data and the signal of enable to gm_tx_d[7:0] interface. - Altera_Forum
Did you create a loopback?
Quartus creates a testbench with the TSE component. It could be a good idea to try and run it and compare with yours.
