About the power supply of cyclone10LP
hello,
I am using 10CL016 F484.
The power supply is used as follows.
VCCIO monotonically reaches 3.3V as shown in the attached figure (ch2).
VCCINT, VCCD_PLL, and VCCA also monotonically reach the target voltage.
However, only VCCIO drops to 2V for a moment after 2ms.
Is this behavior problematic?
If there is a problem, what is the impact?
VCCINT: 1.2V
VCCD_PLL: 1.2V
VCCA: 2.5V
VCCIO: 3.3V
best reguards
Goto
- AminT_Intel
Hello Goto,
I understand you are concerned about the drop voltage value. May I know what IO standard are you using in your design?
Thank you.
- M_Goto
Thank you for answering me.
IO standard is a Single-Ended I / O Standard Specifications.
My design uses 3.3-V LVTTL and 3.3-V LVCMOS.best reguards
Goto
- AminT_Intel
Please refer to this KDB for detailed explanation: https://www.intel.com/content/www/us/en/support/programmable/articles/000078019.html
Thank you.
