M_Goto
5 years agoabout Power Analyzer Tool Report (Cyclone 10 LP)
hello,
We are evaluating the board on which the Cyclone 10 LP is mounted.
In advance, I estimated the current consumption from the project with the Power Analyzer Tool.
I compared the measured values with VCCA (Total Current Drawn) in the report's Current Drawn from Voltage Supplies Summary.
The measured value is larger than the report.
Is the value in the report a Typ value?
How many times the maximum value is the value in the report?
Best Regard
Goto
1 Reply
- sstrell
The accuracy of a power analysis is highly dependent on the input data you provided when you performed the analysis. What options did you choose? Did you provide simulation data that represented how your design would work?
