about Internal Weak Pull-Up(cyclone10LP)
- 5 years ago
Yes, that's true.
Aiman
Please explain further on your question, or you can also refer to below link:
For Cyclone 10 LP
Kindly refer to Cyclone 10 LP datasheet below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10lp-51002.pdf (page 13, Table 11)
Pin connection guidelines for Cyclone 10 LP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-10/pcg-01021.pdf
Cyclone 10 LP device design guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an800.pdf
Aiman
- M_Goto5 years ago
Thank you for your answer to me.
I checked Table 11 on page 13 of the Cyclone10LP Device Database.
Is the weak pull-up resistor as follows?When the weak pull-up resistor is set to ON, the pull-up resistor is inserted before and during configuration, and in user mode.
When the weak pull-up resistor is set to OFF, the pull-up resistor does not enter (that is, high impedance) before and during configuration, and in all user modes.
best regards,
Goto
