lambert_yu
Contributor
5 years agoAbout altera_a10_xcvr_clock_module, CLKUSR pin of Arria 10
Hi sir/medam,
I have one question about CLKUSR pin,
1) From the Arria 10 transceiver PHY UG, it said that if there's transceiver channels in project, it must provide one stable and about 10...
- 5 years ago
Hi Lambert,
I can sense your confusion.
You are still trying to touch on "mgmt_clk".
- You don't need to do any extra connection to mgmt_clk.
- When you instantiate "altera_a10_xcvr_clock_module reset_clock(.clk_in(mgmt_clk))". It basically tell Quartus to do some internal background processing. User is not suppose to use or connect mgmt_clk to any signal (including clkusr)
Let me explain again.
(A) If you plan to use transceiver, provide on board external clock to FPGA clkusr pin
- DO NOT connect clkusr port to anything in your RTL design anymore
(B) If you don't plan to use transceiver, and plan to use clkusr pin as general input clock pin
- instantiate altera_a10_xcvr_clock_module: altera_a10_xcvr_clock_module reset_clock (.clk_in(mgmt_clk))
- You do not need to connect clkusr to mgmt_clk.
- Just use clkusr like normal input clock pin and connect to you RTL design logic.
dlim
Deshi_Intel
5 years agoHi Lambert,
dlim
lambert_yu
Contributor
5 years agoHi dlim,
I got it. Thanks for your help.
Lambert
