MikeH1
4 years agoA10 PCIe Device not seen by Windows
As shown in SigTap snapshot below, there is an extra pulse of app_nreset_status at sample 61. When this happens, the PCIe device does not enumerate correctly in Windows.
I also have a dump of raw ...
KhaiChein_Y_Intel
4 years agoHi,
May I know what is the speed and link width you are trying to achieve? Could you check if the power supply (VCCR_GXB) is set correctly in the Assignment editor and measure the power supply (VCCR_GXB) supplied to FPGA board is matched with voltage set in the design setting?
KhaiY
- MikeH14 years ago
PCIe Core mode is set to: Gen3 X2, 128bit, 125MHz
VCCR_GXB is 1.03V when measured on the board (pins J19 and J20).
I don't see where these pins (J19 and J20) are called out in the assignment editor, where are these located?
Thx.
