A design based on the PCIe DMA transfer example design for Arria 10 device.
Thank you I have got it. And looking forward for the link for the meeting.
1) I have a quick question. The "JTag communucation error" while programming the device happens sometimes (some times it works fine too) do you have any idea regarding the potential reason for this unstable behavior? The hardware is well connected though. Any software crash?
2) Also, even in the scenarios where the JTAG is ready and "Data acquisition in Progress" message is seen in the Instance manager tab, the instance status shows "waiting for the trigger" and it waits forever and no Data is being populated in Data Log plot ? What may be the reason for this?
Is it something to do with my trigger selection? If my counter module has an input ready that triggers the counter to output data. Also a switch to start count and a reset counter. What are the triggers I am suppose to use? Pls see one of the the attached pic to see my trigger selections.
3) If my code has some state selection for a signal (say input=1,) and can I somehow change it in the Signal Tap GUI? Like somehow by setting the Trigger or so?
