5G LDPC IP 版本问题
需要使用5G LDPC IP ,但是 5G LDPC的IP Core又只在Quartus Pro版本里才有, 客户的很多完整设计都是基于Quartus Standard版本 , 需要确认:
1 5G LDPC IP 是否有 Quartus Standard版本 的?
2 能否将Pro版本的5G LDPC的IP Core最终输出成一个网表文件,在Standard版本里调用? 如何解决.qxp 和 .qdb 文件兼容问题。
3 后续的Quartus 19.0 标准版本,是否可以支持5G LDPC IP
1 Reply
- CheepinC_altera
As I understand it, you have some inquiries related to the support of 5G LDPC IP in Quartus Standard Edition. Please see my responses as following:
[CP] No, currently it is only available in QPro Edition.
[CP] Since the IP is built for QPro, you would not be able to to port it over to QStd. Sorry for the inconvenience.
[CP] As I checked into the internal database, seems like there is no support of this IP in Qstd in near future. Sorry for the inconvenience.
Chee Pin
