ZWang142
6 years ago1/2.5/5/10G Multi-rate Ethernet PHY simulation cannot reach rx_block_lock
The simulation of the example design, provided by the "Low Latency Ethernet 10G MAC" IP, is running fine. However, when simulating my design, the PHY can not acheive rx_block_lock. The waveform sho...
Deshi_Intel
6 years agoHI,
Thanks for the clarification.
rx_pma_clkout is derived from rx_cdr_refclk_1. If you have provided correct clock frequency in test bench file then by right rx_pma_clkout should be 156.25MHz.
- I need to understand your design better and try to duplicate issue from my side.
Can you share with me more info as below ?
- Which FPGA product that you are using ? Is it Stratix 10 ? Can you share with me your FPGA part number ?
- Which Quartus version that you are using ? Have you tried with latest Quartus version like Quartus Pro v20.1 ?
- Which simulator tool and what version that you are using ? Make sure you are using the corresponding simulator tool that pair with its Quartus version
- Do you had a chance to try out other simulator tool to see of the issue still persist ?
- Lastly, can you share with me your Multirate-PHY IP setting screenshot ?
dlim
ZWang142
6 years ago0. My rx_cdr_refclk_1 is 322.265 Mhz.
1- Stratix 10, 1SM16BEU2F55E2VG
2- Quartus Pro v20.1
3- VCS 2017
4- I tried Modelsim 10.6 on Windows but it failed to handle long file names. The testbench files provided by the example design have very long file names.
5- Please see the attached
