10 Ethernet in Intel Agilex
Hi ,
Im looking for 10g Ethernet Solution in Intel Agilex SoC.
From the datasheet i have seen that Ftile and Etile hard ethernet IP core is avalible for 10G.
We will be buying the Intel Quartus tool.
I would like to whether the 10G Hard Ethernet IP availble with the tool or do we need to buy the IP separtely.
Linu
Hi Linu,
Intel provides 'Evaluation mode' feature to use Intel`s Quartus tool as well as IPs for initial 30 days for free of cost, here user will have time limited programming files but once this period is over user needs to purchase the license for Quartus & IP as well & that status you can check in IP core summary report,
https://www.intel.com/content/www/us/en/programmable/documentation/esc1425946071433.html#tib15647761...
The Intel FPGA IP Evaluation Mode allows you to evaluate these licensed Intel FPGA IP cores in simulation and hardware, before deciding to purchase a full production IP core license. You only need to purchase a full production license for licensed Intel IP cores after you complete hardware testing and are ready to use the IP in production.
You can refer the Intel FPGA IP cores guide for details,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_intro_to_megafunction...
Zi Ying
- ZiYing_Intel
Hi Linu,
Thanks for submitting the issue.
Please do let us have some time to look into your issue and I will get back to you with findings.
Zi Ying
- ZiYing_Intel
Hi Linu,
Zi Ying
- ZiYing_Intel
Hi Linu,
Since I have addressed your question and you accepted my reply as solution, I am now close the case. If you still have any question after the case closed, please do feel free to submit another issue.
Zi Ying
