17 years ago.mif file generation of perticular freuency
hi, i am facing a problem to generate a .mif file of perticular frecuency for initializing the ROM in my tone generation project...can anybody help me regarding this...
17 years agoThis is where VHDL is significantly more flexible than Verilog. Since VHDL supports all the floating point operations naturally and doesn't complain when a "real" type is being manipulated during synthesis, you can actually code this up extremely generically.
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.numeric_std.all ;
use ieee.math_real.all ;
entity complex_tone_ram is
generic (
FREQ_SAMPLE : real := 50.0e6 ;
FREQ_TONE : real := 4.096e6 ;
Q : positive := 12 ;
WIDTH : positive := 15
port (
clock : in std_logic ;
sreset : in std_logic ;
enable : in std_logic ;
i_out : out signed(WIDTH-1 downto 0) ;
q_out : out signed(WIDTH-1 downto 0)
end entity ; -- complex_tone_ram
architecture arch of complex_tone_ram is
-- Naive search for LCM between sample rate and tone to be generated
function calculate_num_points( sample_rate, tone : real ) return integer is
variable retval : integer ;
begin
retval := 1 ;
while( (tone*real(retval)/sample_rate) mod 1.0 /= 0.0 ) loop
retval := retval + 1 ;
end loop ;
return retval ;
end function ;
-- A constant to hold the number of points
constant NUM_POINTS : integer := calculate_num_points( FREQ_SAMPLE, FREQ_TONE ) ;
-- The RAM type that will be inferred
type ram_t is array(NUM_POINTS-1 downto 0) of signed(WIDTH-1 downto 0) ;
-- A function to populate the RAM
function populate_ram( phase_increment, scale : real ) return ram_t is
variable retval : ram_t := (others =>(others =>'0')) ;
begin
for i in retval'range loop
retval(i) := to_signed(integer(round(scale*cos(phase_increment*real(i)))), retval(i)'length) ;
end loop ;
return retval ;
end function ;
-- The RAM signal itself
signal ram : ram_t := populate_ram( FREQ_TONE/FREQ_SAMPLE * MATH_2_PI, real(2**Q) ) ;
-- Find the location which is 90 degrees out of phase with 1.0
function find_q_start_address( ram : ram_t ) return integer is
begin
retval := 0 ;
for i in ram'range loop
if( ram(i) = 0 and ram(i+1) > 0 ) then
retval := i ;
end if ;
end loop ;
return retval ;
end function ;
constant I_START_ADDRESS : integer := 0 ;
constant Q_START_ADDRESS : integer := find_q_start_address( populate_ram( FREQ_TONE/FREQ_SAMPLE * MATH_2_PI, real(2**Q) ) ) ;
-- I and Q address signals
signal i_address : integer range ram_t'range := I_START_ADDRESS ;
signal q_address : integer range ram_t'range := Q_START_ADDRESS ;
begin
generate_addresses : process( clock )
begin
if( rising_edge( clock ) ) then
if( sreset = '1' ) then
i_address <= I_START_ADDRESS ;
q_address <= Q_START_ADDRESS ;
else
if( enable = '1' ) then
if( i_address = ram'high ) then
i_address <= 0 ;
else
i_address <= i_address + 1 ;
end if ;
if( q_address = ram'high ) then
q_address <= 0 ;
else
q_address <= q_address + 1 ;
end if ;
end if ;
end if ;
end if ;
end process ;
create_tone_output : process( clock )
begin
i_out <= ram(i_address) ;
q_out <= ram(q_address) ;
end if ;
end process ;
end architecture ; -- arch
All will be done at compile time for any particular complex frequency. Obviously this can be adapted to be a real-only tone generator as well. NOTE: Quartus II has an issue with performing a loop more than 10,000 times, but I believe that check can be disabled if you require. EDIT: Also note the Q starting address with be in-phase with the I starting address if the number of sample points is not divisible by 4.
