yzhan286
6 years ago三速以太网IP核接收路径的用户侧少了一个字节
我在使用intel三速以太网IP核时,按照用户手册编写了MAC的配置模块,UDP发送模块和UDP接收模块,目前的发送模块已经测试成功,但是接收模块出现了问题,就是接收模块在对MAC的用户侧(ff_rx_data)数据解析时不成功,为了分析原因,用quartus II中的SignalTap抓取SignalTap抓取ff_rx_data信号,发现数据包的头部少了一个字节,导致了后面所有的数据错位。 ...
Deshi_Intel
6 years agoHi,
Thanks. I understand your problem statement now.
- You are sending broadcast address FF:FF:FF FF:FF:FF
- But Signal_Tap only captured FF:FF:FF FF:FF, looks like last 2 bytes of FF is missing
Couple debug suggestion
- Align packet headers to 32-bit boundary is enabled
- Align packet headers to 32-bit boundary is disabled
- Have you enabled TSE IP statistic counter option and read on register (Dword Offset 0x18 – 0x38) to check on potential error ?
- Did you also monitor TSE IP "status LED signals" to check for potential error ?
- Do you observed TSE RX FIFO underflow or overflow issue ?
- Do you still see similar issue when sending unicast address instead of broadcast address ?
- Do you still see similar issue when sending TCP/IP instead of UDP packet ?
- Lastly, would you be able to perform TSE IP internal loopback testing to isolate external factor issue ?
- ff_tx -> TSE MAC -> ff_rx
dlim
yzhan286
6 years ago您好!
再次感谢您的回复,我在您给的建议下做了如下的测试:
1.使用了本地回环模式即TX->TSE MAC->RX,这个现象依然存在,FIFO端口用的32bit
2.在FIFO宽度设置为8bit的模式下使用本地回环,依然还有这种现象。
3.没有发单播数据报和TCP/IP报,因为我的调试软件在没有知道TSE MAC的MAC地址时不能发送单播报文。
4.FIFO用32bit,不采用Align packet headers to 32-bit boundary ,也有这种现象。
我把我的工程发给您一下。
软件版本是Quartus II13.0 SP1(64bit)
再次非常感谢
